Results 11 to 20 of 24
Thread: This is wierd....20 MPH shimmy?
    sorry it took me so long to reply, my internet was down at work and I stepped out last night. I try to hit these ASAP...kinda a game when I can help.
    Anyways, glad you found the problem before something bad happened.
    Sep 2005
    Goulburn Australia
    I've got this EXACT problem only no noise. I discovered it recently on my trip to see the boys at Oran Park. I pulled the wheel off and put the spare on (brand new tyre). The wobble is still there. I know my rear suspension mounts are on the way so they're getting replaced at my March service. Could bad mounts be causing it?
    Cheers
    Wingman
    '89 525i/A Exec 193000kms
    '94 Subaru Liberty AWD Wagon
    Looking for Merc 300TE
    NSW, Australia
    Sep 2005
    Goulburn Australia
    bump
    Cheers
    Wingman
    NSW, Australia
    Horse Country
    Quote Originally Posted by wingman
    bump
    OT, Wingman your message box is full!
    Dec 2005
    Johannesburg, South Africa
    Default Something wheel related (I think)
    Dont want to hijack the thread, tell me to open another if its the case.
    My car drives like a dream, except if I drive over some types of bumps, holes. It seems the front wheels shake violently (plus steering wheel) whenever I drive over something. It doesnt even have to be deep or nasty, even slightly mis-aligned manholes seem to induce this. I'm pretty sure the back wheels are fine. Any ideas? (I'm very new to the mechanical DIY type thing, have done simple service work i.e. plugs, filters, etc and replaced lights, but no suspension work or such).
    search for "thrust arm"
    Calgary AB Canada
    Quote Originally Posted by Toeks
    I'd say your front dampers (shocks) are baked. I had the same thing when one of my Konis barfed its lifeblood. Every little sharp bump would shake the car and steering wheel but the car never had that floaty effect you see on others with lower spring rates when their shocks fail.
    Anthony
    03/64 production
    Dec 2005
    Default Spot on
    Quote Originally Posted by Anthony (M5 in Calgary)
    Took it too a suspension shop and they confirmed, shocks are worn and bushings need replacing. I want to keep the feel of the stock e34, comfortable ride. So I'm not gonna put in koni's etc. If I lower the springs, what kind of effect will it have? And as far as bushings are concerned, just OE replacements?
    Sep 2005
    Goulburn Australia
    Quote Originally Posted by HDhandyman
    Sorry? I've cleared it up.
    Cheers
    Wingman
    NSW, Australia
    Sep 2005
    Goulburn Australia
    I'm starting to see a pattern with this problem. I intend doing some pretty thorough investigating as to why back RH rear tyres are failing. As my problem is not the tyre (the result) but appears to be the source of the problem I'll see what I can come up with. I want to get it sorted before I ruin another back tyre. My initial fix will be to change suspension mounts. If not fixed I'll then get onto BMA and do the bushes in the rear end. I'll keep you all posted. This does not a appear to be wheel balance problem.
    Cheers
    Wingman
    NSW, Australia
  1. Wierd Mis-fire
    By Washburn in forum 5 Series BMW
    Last Post: 01-20-2009, 11:03 AM
  2. Wierd light behavior
    By Adnan in forum 5 Series BMW
    Last Post: 01-29-2008, 11:27 PM
  3. this was wierd, any one else?
    By barry 90 525i in forum 5 Series BMW
    Last Post: 01-04-2008, 08:33 PM
  4. Wierd problem
    By colamangr in forum 5 Series BMW
    Last Post: 09-17-2006, 01:56 PM
  5. shimmy shimmy shake
    By diamond777 in forum 5 Series BMW
    Last Post: 06-30-2006, 09:32 AM
