Got the Depoeyes from Matrix Racing, they use H1 bulbs for all four beams, used Osram all weathers that promise 30% more than rated light output. Had problems aiming them but after I did, was so much happier with them than old US versions. It's not HIDs, but the improvement is easily 50 % on the dims. And it really looks pretty when them rings light up. However, some issues with the Depo rear clear tails I also put in. Heat from the brake light bulbs deforming the housing, can't even pop the bulb anymore, the holder seems to have fused with housing. Bit worried how I will change this when the time comes. One of their rubber gaskets to the sides of the boot lid has also fallen off. Darn, had I known, should have glued them on...
