Results 1 to 3 of 3
Thread: Need Help Re: Fuel Pump
    Toronto (Area)
    Default Need Help Re: Fuel Pump
    Well my fuel pump died the other day. No big deal, got the new pump, everything is going well until I try to remove the old pump from the tank. I pinched the two ears on the fuel pump bracket to release the assembly, gently pulling up and nothing. The bracket won't release I pull and pull but nothing. It looks like the bracket is being held down somewhere near where a fuel hose is attached. Has anyone out there had the same problem as I am and does anyone have a suggestion as how to get the bracket free.
    Default Did you feel the hooks release? There is nothing more ...
    that pressing the hooks and pull up!!
    Javier
    Toronto (Area)
    Many thanks Janvier! I was finally able to free the pump bracket from the gas tank housing. I needed to use a small set of Vise-Grips to grab near where one of the fuel lines goes to the bracket. It was also interesting to see that the fuel pump housing was cracked almost 3/4 around near the top. Again many thanks for your assistance in this case.
  1. Fuel pump gone; Opel pump fit in BMW?
    Last Post: 09-27-2009, 08:51 PM
  2. Fuel Pump.... Thanks ED
    By joshuagore in forum 5 Series BMW
    Last Post: 12-01-2008, 05:27 PM
  3. Fuel Pump Replacement - Strange Fuel Levels
    By BIGRED in forum 5 Series BMW
    Last Post: 07-11-2007, 10:14 PM
  4. Fuel pump.
    By Rob in forum 5 Series BMW
    Last Post: 12-21-2005, 09:12 PM
  5. Fuel pump IN NEED
    By kyleN20 in forum 3 Series BMW
    Last Post: 08-21-2005, 11:10 PM
