Results 1 to 10 of 10
Thread: Tick-tick- tick noise when AC running-cause?
    Lexington, Kentucky
    Default Tick-tick- tick noise when AC running-cause?
    At idle, I noticed a tick-tick-tick noise only when the ac is running. When the AC is off there is no noise. Just noticed it today! Cools fine. Belts and all pullies and tensioners fairly new. Did not see any wobbles on AC cluthc or tensioners. Cycles on/off fine. Any ideas? Archives were not conclusive.
    I sure hope I am not developing a list of new problems.
    TIA
    Jan 2005
    Chicopee, MA
    Have same problem with mine since I got it.
    maybe the belt?
    Usually it is the belt.
    Lexington, Kentucky
    Default my thought as well
    At least I hope it is the belt. It is only about 15,000 miles old.
    Quote Originally Posted by Tiger
    baton rouge, loserana
    belt with a chunk missing or the tensioner shock for the ac belt
    Shock bad or tensioner wheel bad usually sounds like rattle instead of ticks.
    when you've seen as many of those things die as i have you get to see and hear some unusual stuff, this last saturday we had a 95 525im come in for a set of new headlights, and we just happened to notice the plastic roller was gone on the tension roller at the alternator, and the belt was running on the metal center bearing race, it had to of just happened because the belt wasn't totally eaten up yet, the mystery is that it was able to **** all of the moving parts off the roller without throwing the belt AND without alerting the normally perceptive driver (she usually catches things real soon) weird **** happens
    Lexington, Kentucky
    Will check for sure Now!
    Wow! Darn... never seen anything like that...
  1. E34 M50 Tick Tick Tick Tick Tick... Help!
    By wishihad50k in forum 5 Series BMW
    Last Post: 09-12-2011, 09:07 AM
  2. Tick over / battery ?
    By jrgibb in forum 5 Series BMW
    Last Post: 11-24-2006, 04:23 PM
  3. tick over probs
    By wappy in forum 5 Series BMW
    Last Post: 07-20-2006, 03:15 PM
  4. Bottom end tick. Possible oil pump?
    By Felixdacat in forum 5 Series BMW
    Last Post: 05-04-2006, 03:12 AM
  5. 95 540i engine tick
    By Klaus Schuller in forum 5 Series BMW
    Last Post: 06-01-2004, 01:06 PM
