Update: I think the low voltage is just a bad power or ground wire from alternator. Lots of resistance on the power wire coming from the alternator. The wire gets really hot, too. Will get a reading straight off of the alternator to see if it is better and replace wires and connectors and retest. Will let you know if we need to move on to alternator rebuilds, etc.
The A/C cabin fan is the other issue. There is a variable fan control (not simply 1,2,3,4) on the dash. It only works on the highest setting. How can I tell if I have a "sword?" I believe my car to be an '88 E32 750il manufactured 6/88. How about a blown fuse or sticky relay? It seems strange that the sword (if I have one) took a dump the minute they did this work. Does this car have a "final stage module" as mentioned above or a sword? How do I check? Shogun and I have similar Japanese versions. Shogun (or anyone that knows), which is it?
Whit
1988 750il (whoops, tricky title--probably not a 1994!)
