Results 1 to 8 of 8
Thread: Indy Work Quote Opinions Needed
    Boston & Attleboro MA
    Default Indy Work Quote Opinions Needed
    So I finally admitted defeat in determining the jerking problem and took it to an Indy.
    Here's what they said, Scanned codes had crank pulse generator, cheked sensor signal, checked reluctor ring, found crank pulley wobbling, needs to be replaced w/ sensor.... ~$900
    Sound right? Whats the reluctor ring?
    I know that area is a PITA to work on for the V8s so I'd assume some high labor time.
    Thanks
    Tampa Bay, Florida, USA
    My Indy (Clearwater, FL) charges $75 an hour plus parts; he let's his customers source parts too.
    Get a detailed estimate.
    Ramon
    1994 540iA Nikasil EAT Chip
    Tampa Bay, Florida USA
    Sounds way too much money.
    2nd oppinion is due.
    It may be possible that last person attempt to reinstall the pulley didn't line up the notch and bolted it in... causing it to wobble and vibrate.
    Any guesstimates to what this work should cost?
    The only work I've had done in that area are the water pump & belts replaced, so unless it was bolted in wrong from that, and that work was a while ago.
    maybe the bolt got loose... check it.
  1. opinions needed, 540 for s430?
    Last Post: 02-07-2008, 01:04 AM
  2. considering trade, opinions needed
    By hatched91 in forum 5 Series BMW
    Last Post: 07-25-2006, 06:12 AM
  3. Indy needed for friend in chi-town
    By misfortune in forum 5 Series BMW
    Last Post: 02-14-2006, 06:49 PM
  4. Intake Manifold Off - Opinions Needed
    By myles in forum 5 Series BMW
    Last Post: 07-07-2005, 04:02 PM
  5. Replies: 11
    Last Post: 08-17-2004, 09:18 PM
