Results 1 to 4 of 4
Thread: Question about ellipsoids
    Nov 2004
    Winston-Salem, NC
    Default Question about ellipsoids
    Hey Guys,
    I might be buying a set of ellipsoids soon and need to know if they require any special harness.
    My 525 has a prod date of 3/92 and has the sealed beam lights using 9006 bulbs (I think). Will the 'soids drop in or do I get to be creative with some wiring?
    -ashley
    Paper Gaskets Suck!
    They should fit right in harness wise. You would only need to switch plug ends if you are putting in the Euro variety which are Hx based, not 900x based.
    You'll want to plan to replace the 3 adjuster / mounting screws as part of the swap over. They are typically frozen from age and the plastic tabs are hard and can break when you swap. Good item to source from the dealer; it's hard to figure out what's what in ETK. About $4 each if I recall.
    Plan to take the nose of the car apart to remove the headlight mounting bracket. Bit of disassembly.
    Bellevue WA
    86 Porsche 951 - Track Toy
    Nov 2004
    Winston-Salem, NC
    Quote Originally Posted by Jeff N.
    Thanks Jeff,
    Before I commit to the time and (small) expense of the swap, is it worth it? I mean to stick with 9000 series bulbs and change the assemblies or should I wait and convert to the European Smileys with the H bulbs?
    -ashley
    Paper Gaskets Suck!
    Boston, Ma
    If you stick with US ellipsoids then the wires will be the same, as they are with all 9000 series bulbs. But you will have to change out the harnesses if you goto the Euro Ellipsoids with H1 bulbs. I highly recommend going for the Euro Ellipsoids if you are going to upgrade anyway, they are much better
  1. New Euro Ellipsoids
    By Macv in forum 5 Series BMW
    Last Post: 10-25-2006, 04:47 PM
  2. how to clean my US ellipsoids??
    By schnell944 in forum 5 Series BMW
    Last Post: 09-15-2006, 07:02 PM
  3. WTB: Stock US Ellipsoids
    By cary in forum 5 Series BMW
    Last Post: 10-05-2004, 10:42 AM
  4. ellipsoids
    By darron525 in forum 5 Series BMW
    Last Post: 07-02-2004, 11:11 PM
  5. Replies: 14
    Last Post: 06-01-2004, 09:19 AM
