Similar coolant loss cured by replacing Throttle Housing Heater Plate at 138k on'89 525.
Drove 300km last week, then the "COOLANT LEVEL" came on. I had topped it up a week before, so was a bit concerned. 600km later, the expansion tank was empty again. Drove another 400km on Sunday, and the tank was empty again.
I took it to the dealer this morning, and they pressurised it, but didn't find any leaks and held the presure. They topped it up again, and I drove about 5 minutes down the road and parked. When I parked, there was a steady drip coming from the expansion tank side of the radiator, but I did't open the hood to see where it was coming from.
So I'm thinking that it only leaks when the engine has been running, with a leaking headgasket that would pressurise the cooling system a lot. Since there were no drips after being pressurised with a tester for 10 minutes, and it only leaks when the engine is running.
Anyone got any ideas???
I have a bit of dried crusty coolant there, but a steady drip coming from the expansion-tank side of the radiator. I'm going to assume it just has the typical bmw leak where the expansion tank joins to the radiator.
How much did this replacement cost you?
Failure or leak at throttle housing puts coolant on engine wiring harness to main harness with exposure to corrosion in the contacts. Trust me, you don't want to live through that.
just about the headgasket mate,
it doesnt necceserily have to pressureise
the coolant system, if it "burning"
water, put your hand over the tailpipes
and see if you can feel any moisture,
you know what i mean?
I would do the rad-pressure test to see where is the leak.
Good lucks...
'95 BMW-540i/Auto (ZF-5HP30)...NO reverse
"Original" Nikasil block (+ Fristo Lays Chip)
87+ K Miles
My head gasket leak was hose clamps. Head gasket just replaced by PO. BBUUTT mech reused BMW "one time" hose clamps. Clamps ha appaerntly been reused more than once. Two are leaking. Fix tomorrow.
BMW factory clamps are designed for fast factory assembly, not reuse,
Dan have same problem on my 1994 525i, leak is intermitant will fill up tank and then it starts to leak, other times its fine,how did you get on with yours.
are the gaskets on the expansion tank repairable?
www.KaRealtySF.com
