can of worms?
Looking through the archieves and on the ETM - I see that my 90 535i has a 4 wire o2 sensor. If I go the $39 Ford 5.0 sensor, which is 3 wire - how is it wired up ? Looks like the wires colors on the factory harness are yellow + black + green/blue + green/violet.
Derek A.
90 535i 5 Speed - Style 5 17"
can of worms?
Use the bosch 13275, it's the exact same thing as the stock O2 sensor. 4 wire, etc. It's like $40 or something. I used it on my e30, and it worked flawless, and I would definitely use it on my e34.
Do you know the oem application? Most of the knuckleheds working behind the counter need an application to look anything up - they just can't figure that part number thing right over the counter.
Originally Posted by epj3
Derek A.
so go the save way, use Bosch or Walker and with the connector instead of the one with 4 wires. Also note that there are different ones, our old cars (at least my E32) has only one at the front of the cat, while newer cars have 2 , one in front, one in rear.
https://www.automedicsupply.com/cata...421297a12ee634
Autozone has Bosch 15727 Universal O2 in stock at the store for $60... I find Walker O2 sensor to be cheaper... check with mom&pop part store for Walker brand. I verified the part number for 90 535 with manual twice... I don't know how the other guy came up with different number... maybe auto or 525i.
It's to a chrysler sebring or something... just tell them the number and if they ask for the car, tell them you're picking it up for a friend and you aren't sure, but you know that's the right #Originally Posted by Derek A.
Go with this O2 sensor, don't waste your money for the 15727 that's $20+ more expensive.
Is there a wiring schematic - 4 wire to the BMW wiring harness ?
Derek A.
4 wires - there are 3 colors - there are two gray (or white? can't remember) wires, and they are both the same so it really doesn't make a difference which wire those two go to, but the two unlike colors are important.Originally Posted by Derek A.
