When I first turn on the car the instrument cluster is fine, but as soon as you touch the brake pedal (car is a manual) the cluster tweeks out all the instruemtns excect tach die, but then if you drive the car a little everthing comes back and works fine for the rest of the drive, the other thing is that this tweeking out always resets the trip odometer, although the odomter always reads correctly. Any idea? sounds maybe like a bad ground. Also dose anybody have some black door panels?
