Results 1 to 7 of 7
Thread: Question about Depo ellipsoid bulbs--help needed
    Mar 2004
    Default Question about Depo ellipsoid bulbs--help needed
    I think I have the wiring figured out, but I took a regular H1 bulb and tried to put it into the housing, and the bulb didn't fit through the metal opening. Am I missing something here???? What kind of bulbs do I need to get?
    *Thanks*
    Mike S.
    1992 535iM black/black
    1997 540iM white/gray
    Retired: 89 535iA, 85 318i
    <<Support your local autobahn, stay out of the left lane!>>
    depos take the 9005/9006 bulbs
    Are you sure you got H1 bulb?
    Mar 2004
    Yes, and the depo housing, the plastic cap, does say h1 on it. I'll try the 9005,9006 next. Anyone else know?
    Mike S.
    Wellington,New Zealand
    the h1 bulb doesnt go into the housng,it kinda sits on the outside with the cut of side of the circular base mating to the flat on the headlight.The bulb is held in place with a double sided spring clip.You can see the shape of the h1 base in the pic.The headlight housing obviously must be a mirror image
    Gone but not forgotten
    sometimes the casting of the Depo light housing has some extra metal in the bulb opening. Check to see if it looks "finished" and if not try an emory board/nailfile to grind-off/file-off the flanged metal leftover from the casting. I recommend doing this with the opening facing the ground so the filings don't get trapped inside the housing. Finally, blow-out the housing with compressed air. I got the same set-up with HID 4500k bulbs...............sweet.
    Mar 2004
    Thanks for the responses. They were H1 bulbs after all, I was mistakenly trying to fit an h7 bulb earlier, till I looked closer. Got them installed today, I have some MAJOR aiming adjustments ahead of me!
    Mike S.
  1. Headlight Bulbs, quick question
    By boardburton in forum 5 Series BMW
    Last Post: 08-08-2006, 09:13 PM
  2. OBC bulbs, confirmation needed
    By ra_pro in forum 5 Series BMW
    Last Post: 12-21-2005, 09:12 PM
  3. question about HID bulbs
    By tnt525i in forum 5 Series BMW
    Last Post: 09-20-2005, 03:15 PM
