you're right qsilver7, i'm in southampton,england. the keys look like item 7 in your parts diagram link as they have 2 buttons, square to unlock and circle to lock. each key takes 2 panasonic CR2016 3V batteries, if that helps?
...do you carry the key in your pocket? If yes, could it be that the buttons are being compressed while you are sitting or moving around thus unbeknownst to you, expending the battery's life? A solution would be to rest your key in a place where the buttons can't be pressed, like on a ring attached to your belt loop. I would give other suggestions but don't know if you're male or female.Originally Posted by bun525sea
Q
95 525iT / 97 740iL
