Results 1 to 3 of 3
Thread: 525i se auto 1992
    Apr 2005
    Default 525i se auto 1992
    can anyone help a newbie please.car wouldnt start while out starter motor not even trying to turn over engine.got towed home and had a new starter motor fitted got started but 4 hours later when i tried the car nothing again so charged up battery .next day refitted battery and car startedcstraight away,but 5hours later tried it again and same problem not evening try to turn over.checked immobiliser that was ok, battery charged ok so what else could it be
    Mar 2004
    Toronto, Canada
    Did the battery charge from the alternator or did you charge it with a charger?
    Sounds like you've either got a bad alternator which is not fully charging the battery.
    Or, if this power drain only happens after the car is sitting for awhile, you've got something left on or you have an electrical short somewhere.
    01 740i sport
    92 535i
    92 525 touring
    88 325ic
    I'd check the voltage regulator, make sure the battery's actually charging. If that's okay, have a load test done on the battery at the local AutoZone.
    Best, whit
  1. Questions: 525i CD changer (1992 525i)
    By BMW525i in forum 5 Series BMW
    Last Post: 07-18-2004, 05:33 PM
