Results 1 to 2 of 2
Thread: m30 valve adjust frustration solved
    Apr 2004
    Default m30 valve adjust frustration solved
    Adjusting BMW valves since 1968 but seemed to have lost touch or aged out. Eccentric seemed to move as nut was tightened.
    Finally solved. Black gunk deposits in head apparently in valve adjusting part of rocker as well. Eccentric resisted movement. Flushed well with solvent while moving eccentric until completely free.
    Voila
    Gene....I know what you're talking about, man! The gunk *sucks*. I guess it's time to put some Delo in the crankcase (or whatever Ryan R. was talking about) to clean up the varnish and other nastiness in my car's top end. Then, it'll be back to M1 0w40.
    Three for getting your valve adjustment technique back in shape.
    best, whit
  1. How Do I Adjust Idle?
    By bad2buck in forum 5 Series BMW
    Last Post: 04-29-2009, 04:58 PM
  2. Rear suspension frustration
    By markwascher in forum 5 Series BMW
    Last Post: 03-12-2008, 04:29 AM
  3. '87 325 rod knock or need valve adjust
    Last Post: 11-21-2007, 11:13 AM
  4. 15w-50 Mobil 1 seems to have solved my valve chatter
    By Dick Schneiders in forum 5 Series BMW
    Last Post: 04-04-2004, 01:10 PM
  5. Replies: 3
    Last Post: 02-24-2004, 01:21 PM
