At the back of the panel, pry it open with a screwdriver, use a cloth to protect the headliner. It comes out in the direction shown above, very easy, don't be scared. =)
Jr
Jr
...it may be slightly larger than the sedans plus the sunroof tool is stored here on the Touring instead of in the tailgate's tool kit. Note the black tabs around the panel that help secure it in the roof/ceiling. The switch is easily removed from the panel and the light bulb will need to be soldered in. I found a 12volt bulb at a hobby shop to replace mine with. just make sure the bulb will fit in the space...I also had to strip back some of the insulation on the wires (again very easy) then soldered the wires. Bingo! switch lights up perfectly and now I can see it in the dark!![]()
Q
95 525iT / 97 740iL
