My recent experience- still all good
Recently I had my indy put in amost 7 quarts (empty about 8.8 quarts) of Mobil 1 synthetic atf with a new filter kit. They drained and cleaned both pans and blew air through the oil cooler lines to remove as much of the old fluid as possible. They left the old atf in the torque converter as there is no drain. Note, they did not flush, they drained.
BTW, the trany had been fully serviced with filter etc. about 31,000 miles ago. While I did not notice a problem before the change, It seems as if the trany now shifts slightly smoother and has a littlle bit more pep off the line.
__________________
Originally Posted by
525e34
My "new" 1995 525i has 98k miles and unsure when/if the PO last changed the auto tranny fluid. No problems with performance ( GM A4S 310R ) - just bothers me not knowing. Here is my "cautious" ( anal ) approach in case the fluid has never been changed:
1) Drain pan only and refill with Mobil 1 Synthetic
2) Drive approx 500 miles
3) Drop pan & sump, replace fluid, new filter, gaskets and Mobil 1
The thinking is the first change should allow the Mobil 1 to clean out/loosen crud, the second get it out of the transmission. This seems to be the common theme in previous posts. Any other thoughts?
Also -is there a crush ring on the drain bolt? Can't find any listed on parts websites and my filter service kit doesn't have one.
