Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: No oxygen sensor !!!
    Wellington,New Zealand
    if your engine temp sensor for ecu is bad this will cause rich running,or if thermostat stuck open car will run cool and therefore rich.....
    Gone but not forgotten
    Default Ali
    the oxygen sensors are quite expensive from the dealer. i think you should at least try to use your credit card payment with known companies like Peake research and also with Oxygen Sesnors Co., where you can buy a original Bosch with the right plug (the the universal one) for only about 75 US$
    https://www.automedicsupply.com/cata...91fae326fa78a#
    https://www.automedicsupply.com/faqs...091fae326fa78a
    If your exhaust does not have a connection: any exhaust shop has threaded pieces for weld on to the exhaust. That is often required when the old one is corroded and when removing it the whole threaded piece sometimes breaks out of the exhaust.
    The wire at the end seems to be the one for the reverse light. If it is connected and the reverse light is always on, check the switch which is under the center console (reverse light switch). Maybe it is misalligned or out of order. Use the online spare parts catalog (ETK) to find the correct p/n.
    Not very expensive.
  1. $775 Oxygen sensor in NC
    Last Post: 11-01-2007, 07:04 AM
  2. oxygen sensor 1 is bad which do i replace
    By 94530inh in forum 5 Series BMW
    Last Post: 11-29-2006, 08:34 PM
  3. Need help removing an oxygen sensor.
    By nmwaldron in forum 5 Series BMW
    Last Post: 10-04-2006, 07:32 PM
  4. which Oxygen sensor is #2 ??
    By lvngdead in forum 5 Series BMW
    Last Post: 06-10-2006, 01:46 AM
  5. Oxygen Sensor
    By jbw535i in forum 5 Series BMW
    Last Post: 03-24-2004, 11:38 PM
