Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: laptop holder pics
    ukm5 Guest
    Quote Originally Posted by Jeanfb
    How is it attached to the floor/seat rails? I need details if you don't mind, I need to build one as well...Thanks a million.
    its quite easy, perhaps a little crude, but it works and i find having a laptop in the car with navigation on worth the rather aggressive iron work!
    its bolted to the floor, i took up the carpet, well partially as to remove competly is hard work - i welded a steel pin about 1 inch diameter and about 6 inch high to a square plate, make the plate as small as possible as the floor isnt flat for more than a few inches in any one place and therre are lots of obstacles like brake lines under the car. then i pushed the pin through the carpet so all you see after the carpet goes back down is the pin. the plate is bolted through the chassis and a plate of equal size placed on the underside of the chassis and bolted together
    the holder is basically a piece of bended aluminum tube with an internal diamete to fit over the pin snuggly, as i say about 1 inch diameter. then a flat plate fasten to the top for the laptop to site on. if u look in the pic i have also attached springy steel clips to the side to stop it falling off when braking.
    as i say its a little crude - the holder itself can be simply lifted off and placed in the house and all you see if u look is the pin
    just bear in mind the position of the seat, dont make the pin so high as to restrict the seat moving forwards. i have made it so the seat can move fully forward when the holder is not in position as the seat just clears the pin however when using the holder i move the seat back to allow a clear vertical connection to the pin
    also add an r clip to the tube to stop it swivelling.
    That is great thinking - but a little agressive for my taste - I don't plan on pulling the carpet - will investigate attaching to the seat rails...I might incorparate some (all) of the other details ( r-clip etc....) thanks again.
    ukm5 Guest
    a laptop is heavy, im my opinion if u dont be aggressive it will flap about then just fall apart. the metal under the seat is by no means strong enough to support it. the rails have no positions u could attach to without affecting the movment of the seat. also how do you change the angle...the seat metal starts someway under the seat you would have to make a bracket to come out at right angles therefore loosing all strength
    That is absolutly awsome! Ill bet we see more of these in a short bit...and then on Ebay.
    you should pick up a black dvd-rom drive and get an adapter to run it via usb to your computer and slide it in the din slot! That would look nice!
    Black/Black '90 535IM..... '65 Cal look vw bug
    ukm5 Guest
    Quote Originally Posted by casurfer911
    i never understood why anyone would want/need a dvd player in their car! whatd the point you really going to sit there and watch a 2 hour movie!
    it purely for sat nav!
  1. anybody need a laptop
    By winfred in forum 5 Series BMW
    Last Post: 11-24-2008, 06:22 PM
  2. anybody have or know of a deal on a laptop?
    Last Post: 03-02-2007, 11:11 AM
  3. OT: how to charge laptop battery outside of laptop
    By Elekta in forum 5 Series BMW
    Last Post: 08-21-2006, 02:39 PM
  4. OT: laptop experts please help.
    By Beez540 in forum 5 Series BMW
    Last Post: 05-01-2006, 05:44 PM
