Results 1 to 8 of 8
Thread: HID Bulb Funny Looking?
    T·O·R·O·N·T·O
    Default HID Bulb Funny Looking?
    Yes, that's a strange title, isn't it?
    Does this look right? Everything was wonderful until one of the bulbs continued to turn off and refused to turn on until what seemed to be a ‘cool down’ period. I tried running the bulbs in and outside of the headlamp with the same issue. One of the bulbs (same one always) would go out after a while. It originally was about 15 minutes, then got progressively shorter. Now it would turn on, then turn itself off under 2 minutes. I would then need to wait about 5 minutes before the bulb would reignite.
    I noticed something strange about it as well. There is a yellowish liquid inside the center of the bulb… but I deemed that normal because both have that. However, the suspect bulb center looks frosty and has a lot of that yellow fluid. The ok bulb has a bit of yellow fluid but is overall transparent.
    Hmmm... this is indicative of a cheap, defective bulb?
    One thing I haven't tried... plugging this bulb into the other ballast/starter, but I thought I'd ping this forum for possible suggestions. Perhaps someone else has seen this.
    CT
    may be a biaach but the only surefire way is to swap the bulbs/ballasts to find out what is suspect.
    King Of NYC
    Wellington,New Zealand
    it is posible that it is the lkm?????,how hard to try a normal bulb or as you say switch bulbs....
    Gone but not forgotten
    PA
    Quote Originally Posted by Paul in NZ
    Could be a bad solder point in the LKM MAYBE... but it is more likely the bulb or ballast.
    I have phillips bulbs/ballasts there is no liquid in the capsule...
    check here:
    http://www.hidplanet.com/forums/
    T·O·R·O·N·T·O
    I've done some more narrowing down and it's either the wiring to the ballast or the ballast itself...
    BTW Thanks for the forum suggestion!
    T·O·R·O·N·T·O
    Well it's the Ballast. I ran a parallel voltmeter and during the entire time, the harness was supplying 11.8v up and through the point of failure. I've contacted Kaixen of Korea and they are having me ship the ballast back at THEIR cost and will send a replacement. There is a 14 month warranty Awesome folks (so far)!
    awsome yes...what do you do in the meantime without headlights?
    if it is decent kit he wll just put the standard bulbs back in!
  1. Parking light bulb = signal light bulb?
    By bigtisas in forum 5 Series BMW
    Last Post: 11-06-2006, 11:52 PM
  2. Bulb out?
    By BFEINZIMER in forum 5 Series BMW
    Last Post: 10-27-2006, 02:09 AM
  3. Replies: 11
    Last Post: 10-04-2006, 06:35 AM
  4. Which is the best H1 bulb?
    By 1991 525i Novs in forum 5 Series BMW
    Last Post: 08-04-2006, 04:11 AM
  5. Bulb for key
    By GoldenOne in forum 5 Series BMW
    Last Post: 05-23-2006, 06:16 PM
