Results 1 to 2 of 2
Thread: Instrument Panel locking-up
    Apr 2005
    Default Instrument Panel locking-up
    My 735/88's instrument panel locking up from intermittently, i.e. only the speedo works, but none of the other instruments (often the fuel, temp, rev and fuel consunption meter will lock-up in mid to low ranges) I have to switch off the ignition, wait for a while and start again. I seem to be more successful (perception?) if I start the car quickly, meaning, not to stop at the accessory only position - straight to crank.
    The other related? problems:
    The temp sensor often shows -37'o cel. usually happens if I use the horn or something like it.
    The low beam does not come on straight away, (no problem with any other lights), it come on after a while though.
    All the above problems are getting more frequent.
    Any help will be appreciated.
    Default let's start
    dash cluster lights prob could be the infamous capacitor problem. But can be easily solved
    http://shrubbery.student.utwente.nl/...dash_caps.html
    Temp sensor -37 means that it is out of order. Either the sensor itself or the connection there.
    http://shrubbery.student.utwente.nl/.../OBC_temp.html
    Low beam problem: start your soldering machine. Common problem. Go to my page and then click on e32fixes.com and look for LKM and mustard relay fix/soldering
    http://tridem.han-solo.net/auto/erich/auto.htm
    It is also described on Bruno's page e34.net, see link on my website.
  1. Another instrument panel question.
    By M-what in forum 5 Series BMW
    Last Post: 09-29-2007, 11:55 PM
  2. Dim Instrument Panel
    By Kobe Diesel in forum 5 Series BMW
    Last Post: 01-05-2006, 12:51 AM
  3. Instrument Panel, for the EXPERT
    By SLDB in forum 7 Series BMW
    Last Post: 07-25-2005, 03:05 AM
  4. Instrument panel
    By sparky63ten in forum 5 Series BMW
    Last Post: 04-27-2004, 12:51 AM
  5. Instrument panel bulbs
    By Karl in forum Electronics & Lights plus A/C
    Last Post: 04-18-2004, 12:09 PM
