Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: hitting type sound from the rear of the car
    Default hitting type sound from the rear of the car
    I'm hearing a hitting type sound coming for it seems the rear left of the car. It's not the subframe bolts. I can't describe it well. Today I moved the exhaust around a bit, about 1.5" of play. I couldn't notice anything unsuall and don't have pics (it's dark outside).
    I been reading a few other posts and think it maybe this.
    http://www.bmwe34.net/e34main/Mainte...terBearing.htm
    But the sound still happens at higher speeds over 80 kms.When I turn right, i can barely hear it, but when i turn left, its a lot louder, going over bumps also makes me go eek!
    Or I can check the exhaust hangers. Any other help guys?
    Have you checked the subframe bushings? Look above the bushing and see if you have very clear marks on the floor pan. Did you retorque the subframe nuts well after you put in the plates?
    Will it make the noise if you get on/off the gas in a straight line?
    Is it a "thud" or a "whhrrrrrrrr" type sound?
    Bellevue WA
    86 Porsche 951 - Track Toy
    Quote Originally Posted by Jeff N.
    Hi Jeff,
    I know it's definately not the subframe bushings bolts again. You can see the delrin plates there, but I'm certain there on tight. My mate bolted them up first, then I had a quick go. They are tight.
    I drove the car home from work this evening. I don't think there is noise when I get on / off the gas.
    It a thud type sound.
    I hope this helps.
    probably the muffler swinging over, might need fresh exhaust hangers. The old ones get kinda mooshy after a while.
    I'm going to second that. If they're loose, the thing will chatter as it hits the heat shields.
    Dayton, Ohio
    I've got a similar noise... but I only hear it at low speeds over bumps...
    I'll prolly crawl up under there and take a peak at it this weend
    Former: 95-530iM
    Current: 99 GMC Seirra 1500
    Default i have video of what it sounds like
    here is the download. ftp://divineftp.no-ip.org/jap/soundrear.wmv. The file is 2mb in size.
    As you can see / hear - as the car goes over the bumps in the road it's making a hitting / screaching nosie. I'm going about 90km down the hill.
    I spoke to Martin in Bellveue, he suggests its either a rear dried out shock or the center support bearing. cv joint or halfshaft or even a rear wheel bearing. I don't think it's the top rear strut mount.
    Can anyone else give advice - I don't want to take it too a mechanic.
    Feb 2005
    brisbane
    lay off the track days for a while kriss,
    it sounds like you have broken your diff side bearing
    Bellingham
    Quote Originally Posted by BigKriss
    From that list, I can only imagine it would be a dying shock. Given the constant creaking as the rear suspension moves, that's really all it can be.
    CV joints and associated parts would make noise that is dependent on torque and/or speed. This doesn't seem to be the case. This sounds to be solely caused by the movement of the rear suspension. no?
    Given the loudness and the knocking/hitting sound - I'd imagine this should be pretty obvious to the eye. To make a hitting sound, something has to be loose. Perhaps a trailing arm bushing? Maybe a REALLY dead pitman arm?
    You are SURE it's coming from the rear, right? What all is non-stock in your rear suspension?
    Also; I was confused as hell for a second with the camera on the left side of the car - my brain must be going slow today.
    Quote Originally Posted by Mobius
    I check the left hand side rear pitman arm (aka dogbone), and it was damaged, there's a about 1.5 cm of play, It's broken. I have one pic, its poor quality. Luckily, i have a new set in the garage, now begging to be put on.
    thanks mobius, i won't be driving untill its fixed. I'll have to put the new set on in the next few days.
    http://www.bimmer.info/forum/attachm...tid=1074&stc=1
  1. VIN & Rear end differential type
    By Claude in forum 5 Series BMW
    Last Post: 10-12-2009, 11:24 PM
  2. proto type rear trial shade clips-pics
    Last Post: 08-01-2008, 06:37 PM
  3. clunking sound in rear at 25 mph.
    By adamhop in forum 5 Series BMW
    Last Post: 02-15-2007, 01:36 AM
  4. Replies: 3
    Last Post: 06-30-2004, 04:40 PM
  5. Got a sound coming out of my rear...
    By THUCK in forum 5 Series BMW
    Last Post: 04-28-2004, 10:35 PM
