Thread: P/S hoses, other cars, and the silly Roundel Ads
    Gainesville, FL
    Default P/S hoses, other cars, and the silly Roundel Ads
    I've got a 3 part quesitons here.
    1. I need 3 short rubber hoses for my power steering system of roughly the same length, with the dimentions 12x18mm. BMA wants like $25+ for each of them and i was wondering if any rubber hose would do? I figure home depot probably has something smiliar for like 50cents a yard that would work just as well. the hose is pictured here as item 8 http://www.realoem.com/bmw/showparts...80&hg=32&fg=20
    they don't appear to be under any large ammount of pressure and have no special fittings.
    2. If you wanted someting a lot smaller, lighter, sportier, cheaper, easier to fix, and that got better MPG than your big smooth 5-er what would you consider buying? i was thinking e30/e36 maybe.. or maybe a japanese import.. an older one in good condition. something you could take apart like legos on the weekend just for fun and not spent anyhting to rebuild. a fun little city-daily driver if you will.
    3. Anyone ever notice how high some of the prices on Cars for Sale in the back of the roundel are? i see a 94 530 with 113kmiles and normal replaced items for $10K and another 530it with an abigously new transmission and 130kmiles for $12K.. is it the alusil engine replacements done recently? sheesh. i should just sell mine in here, buy a new one on ebay for like 6,000 and use the profit for upgrades.... even in ok condition, using those numbers, i could ask like 7.5 or 8
    Honolulu
    Default Spend the bucks and buy the right hose.
    1. The Home Depot stuff may not be oil & gas proof, and will swell up and turn into a soft gummy tube of goo.
    2. I don't know about anyone else's experiences with Japanese cars....But I find them built to be disposed of, and not to be maintained. I like the E34, because I can actually fix the car without turning into a contortionist or hiring a Smurf to turn a nut in some ridiculous location.
    Nov 2004
    I second that opinion BlitzK!. The hoses aren't that expensive and they will last a long time. You probably never need another one for the life of the car.
    E34 are easy to fix an d solidly built. The Jap stuff are ok only if they are younger than 6 years and are well kept. My 89 E34 sedan drives just like a new car and I get the fulfillment of the experience everytime I use it. I can't say for any other make.
    I would get the correct hoses. The power steering circuit out of the pump operates at a really high pressure, IIRC.
    If you really aren't having much fun with your 530, you could always just give it to me
    best, whit
    Bellingham
    For the hose; it doesn't appear to be on the high pressure side of the pump (no high pressure line is going to be clamped with hose clamps); so you may be able to get by with some random hose. I'd absolutely look for a high pressure fuel or hydraulic hose, to be safe. Anything you use should be marked safe for use with oil.
    Wellington,New Zealand
    toyotas are bulletproof.....for 200 000 ks anyway.....
    Gone but not forgotten
  1. Really silly question--
    By High Compression II in forum 5 Series BMW
    Last Post: 10-17-2005, 10:49 AM
  2. silly question
    By rellik in forum 5 Series BMW
    Last Post: 10-09-2005, 07:53 PM
  3. This is getting really silly!
    By GJPinAU in forum 5 Series BMW
    Last Post: 08-04-2004, 06:36 PM
  4. How long to keep older cars? Good ROUNDEL article
    By Warren N.CA in forum 5 Series BMW
    Last Post: 02-25-2004, 01:13 AM
