Copied from another page: The brake system uses a glycol-based hydraulic fluid. The fluid is "hygroscopic," which means it tends to absorb moisture over time (never leave a can of brake fluid open for this reason). Moisture lowers the boiling point of the fluid and causes internal corrosion in the brake system. That’s why the fluid should be replaced when brake repairs are made or every two years for preventive maintenance. There are several different types, based on the boiling temperature and other characteristics of the fluid. DOT 3 or DOT 4 is used in most passenger cars and light trucks. Use only the type of fluid specified by the vehicle manufacturer. Using DOT 3 in an application that calls for DOT 4 might create a safety hazard. DOT 5 brake fluid is different from DOT 3 and DOT 4 in that it is silicone-based. DOT 5 is NOT recommended for any vehicle equipped with antilock brakes - but it can provide long-lasting protection against corrosion for vehicles that are stored for long periods of time or are driven in wet environments.
