I suspect the burn off cycle is the reason hot film MAF's were developed. Do any mfr's still use hot wire MAF's? Certainly you don't want any liquid to contact the hot wire/hot film. But starting fluid evaporates so rapidly you'd almost have to aim the stream at the sensor for this to happen. The air flow straightener further blocks a direct shot at the sensor.
Paul Shovestul
Originally Posted by
Derek A.
Keep in mind to that those hot wires are not supposed to burn off very much. If you soak them in starting fluid - you could create enough of a short that it screws up the MAF. Have seen guys with E39 528s that put cheapo cold air kits that suck water on torch the MAF sensors.
