I emailed whiteline again today. www.whitline.com.au. I asked them if they can make bars over 20mm. Here is what they replied with
"The next available sizes up are 22mm or 24mm. We can make these sized sway bars, but we may not be able to supply 'D'-bushes to suit this size bar, nor do we accept any responsibility for the sway bar.
Another problem that you will find is that you may not be able to mount the ride height sensor as the U-bolt only just fits over the 20mm sway bar.
You have mentioned that no other manufacturer makes the sway bar larger than 20mm, may I suggest that you ponder why this would be the case, as I believe that if you increase the size of the rear sway bar too much you are going to suffer from o/steer"
My initial queries on this response was;
- get the 20mm polyurethane bushing and drill them out 2mm more by a shop
- the ride height sensor they talk about is only on the m5 with adaptive suspension - i thought my car did not have one
Is anything over 20mm too big, or can a 22mm or 24mm bar be appropriately fitted to the car?
Guys running with 19mm or 20mm bars, does it look like is appropriate clearence for a few more mm?
