bulb light sockets inside the trunk, CAREFULL WITH POLARITY (allways atach negative donor lead to chassis metal). Unlock and go as usual.
Javier
So. my battery is dead.., and I can't open de doors because of the power failure
Any suggestions
Javier
Do you have a picture of the exact place to put it?Originally Posted by Javier
Could you be nice and give me a step by step instructions??
tnx
Your owners manual has a section about the emergency unlock procedure...look at emergency operation in the right column at this link: http://luuk.xs4all.nl/bmwboeken/bmwe34manual/pg7.jpgOriginally Posted by gabrielf
Basically, you lift and hold up the passenger door handle while (at the same time) turning the key to the emergency unlock position. Sometimes you may have to "pump" the handle and exert more than normal pressure to get the key past it's normal detent. This is because you have lost the "electrical" assist. If you are unsucessful on the passenger side....then try the drivers side...but remember the driver's lock goes in the opposite direction of the image below.![]()
Q
95 525iT / 97 740iL
