Results 1 to 8 of 8
Thread: To all manual Bimmers, watch who u giving it to!!!
    Jan 2005
    Chicopee, MA
    Default To all manual Bimmers, watch who u giving it to!!!
    Recently I gave My 525 for a test drive to one of my friends, and unfortunately he does not have much experience with driving a stick. The drive wasnít exactly the smoothest one; you know all how the beginnings with a manual tranny are. Making story short, we got to a set of red lights that were uphill (a very steppy one), so I think we screwed. To make it worse some motha in a big SUV sopped few inches off the bumper. That was the moment when I started praying that we donít end up bumping into the car behind us. Fortunately it wasnít the case, as I thought my buddy panicked. He pressed gas and clutch at the same time. And you all know that there is no better way to burn the clutch then doing that. My poor baby was being slathered until white smoke came out from under the hood with a really strong clutch smell, then it stalled. After waiting few minutes until all the smoke was gone I started the car. Cultch was feeling really soft, but there was no other damage that Iíve noticed. After driving home about 30 miles the pedal became harder but it dropped about an inch or two. Also you can minimally smell burned clutch, especially when the heater is on. Any suggestions?
    Melbourne, Australia
    Quote Originally Posted by TheDuke
    1. You won't let someone who doesn't know how to use a manual trans drive your car again will you?
    2. Your clutch is burnt out.
    3. Remove transmission & replace the clutch plate, pressure plate & thrust bearing and machine the flywheel.
    4. Replace transmission & road test.
    5. Refer to point 1.
    Naww, I doubt it would burn out on a single fry. More likly the pressure plate got blued and will slip a bit until it breaks in again. The smell will go away eventually.
    shoot your friend THRU his wallet, then realize that he shouldn't have asked to drive your car if he was unfamiliar with driving a manual transmission, sometimes friends are the worst enemy............I would have it diagnosed professionally, and inform your friend of his new "monthly payments"
    You would be surprised just how quickly a clutch can be fried. I've seen a brand new clutch burnt out in under 60 secs by someone trying to reverse a trailer up a driveway. It came good for a short while, but the damage was done. Had to be replaced again within a month.
    Jan 2005
    Chicopee, MA
    I've seen tucks with loads burning clutches because of incompetence of the driver quite few times. Now every time I let anyone drive my car... wait right now no one is allowed even to touch the steering wheel, well except for my bro, but he has more then plenty of experience driving a stick. Actually you could not smell the clutch this morning so I think it should be ok. I guess about 5K of live spend of the plate went to hell. But just in case I'll check BMA Prices.
    Nashville, TN
    Its a dual mass flywheel - you cannot machine it. Average street prices are usually around $500.
    Derek A.
    90 535i 5 Speed - Style 5 17"
    Jan 2005
    Chicopee, MA
    If the plate isn't damaged the flywheel should be fine right?
  1. Help: OBC display disappears when giving gas...
    By mancini_mark in forum 5 Series BMW
    Last Post: 10-26-2005, 09:48 AM
  2. Replies: 6
    Last Post: 07-26-2005, 09:50 AM
  3. Replies: 0
    Last Post: 04-26-2004, 02:54 PM
  4. 14k on o2 sensor and giving a
    By robertg in forum 5 Series BMW
    Last Post: 04-01-2004, 02:34 PM
