Results 1 to 10 of 11
Thread: Body shaking at 50-60 MPH
    YoDaddy Guest
    Default Body shaking at 50-60 MPH
    Hi all. I just upgraded my 15 inch stock wheels to 17 inch Mille II wheels and Falken tires. The wheels are used but look to be in great shape while the tires are brand new. At 50 mph the car starts to shake...at about 60 mph the shaking smooths out... The tire dealer reset my frontend camber and has done everything possible...mutiple balancing, rotated the tires on the wheel and has indicated that he will replace the tires if need be. The dealer is a great guy and I would like to spare him the hassle of going to new tires. Any suggestions? I was also wondering if the tread pattern was at fault. I had no problem with the stock wheels and tires. Thanx
    1995 525i
    JC Chip
    Euro Impact strips
    72000 miles
    SCHUYLKILL COUNTY, PA.
    Default thrust arm bushings
    have you changed the thrust arm bushings. the wider grippier tire will make the shake more noticable. i had to replace mine 4 months ago. i replaced the thrust arms with the 750il bushings (they are heavier), tie-rods, & center link. the mechanic that aligned the car told me my 540i was one of the tightest front ends he ever worked on.
    tim s.
    1995 540i/a
    1987 325e
    Check this link out for more info. on the thrust arm bushings: http://www.bmwe34.net/e34main/Mainte.../Upper_arm.htm
    my car just started to do the shimmy...
    YoDaddy Guest
    Default Thanx for all your responses..
    I had the thrust arm bushings replaced about 4000 miles ago...I think I will have the shop look at the driveline and the joints...if they pass muster I will try a new set of tires (possibly upgrading to the next level of quality)..Thanx for all your responses...
    around Toronto, Ontario
    Do the wheels go on snugly? Are you sure they don't require hubcentric rings?
    The tires might simply be out of round (you get what you pay for...I know my Kumhos aren't perfectly round, the tire noise is periodic).
    Quote Originally Posted by YoDaddy
    1995 525i
    JC Chip
    Euro Impact strips
    72000 miles
    i just did a 91 535 that was crashed so hard the driveshaft was bent, oooo nice car, the farking driveshaft tunnel is deformed so that the tranny xmember doesn't sit straight, and no this aint the worst "fixed" wreck i've worked on
    in a sexy house
    Default Hubcentric Rings? If not - that's the problem.
    Why does the new format FORCE a body of the message?
    '90 525i Guest
    Mine did the exact same thing at the exact same speeds when i bought it. A front end allignment cleared it all up, no probs.
    Wellington,New Zealand
    Default again make sure your wheels are correct.
    the hubs are 72.5 mm dimeter on the e34 many aftermarket wheels and some bmw wheels are not.Hub centric rings make sure the wheels are concentric to the hub.....
    Unregistered Guest
    Definetly check about your control arms and tie rods. I have the same problem it it becomes extremely noticable when on a downhill slope and braking at higher speeds unless i press the brake to a certain point.
  1. Shaking @ around 85 mph and above
    Last Post: 03-12-2009, 03:14 AM
  2. Please help violent shaking
    By nesone0072525 in forum 5 Series BMW
    Last Post: 02-10-2007, 11:24 PM
  3. steering shaking...
    By Monastie in forum 5 Series BMW
    Last Post: 02-07-2007, 01:00 PM
  4. car shaking in idle
    By anders in forum 5 Series BMW
    Last Post: 09-29-2006, 06:54 AM
  5. e36 shaking at 100+kph
    By Incantation in forum 3 Series BMW
    Last Post: 04-18-2006, 03:06 PM
