Originally Posted by
gale
e32/e34 diff's will interchange but I believe M5's are different. You may have to swap the input hub and/or axle output hubs depending on the year and whether the diff is from a manual or auto. I believe only lsd to lsd axle hubs can be swapped, open diff's have a different arrangement for how the hubs attach and are attached internally? Lsd hubs come off really easy, just pry on the outer flange lightly with a screwdriver and it pops an internal snap ring out of a groove. Just be careful to put them back in lightly and rotate them slightly to register the splines before tapping them in with a rubber hammer. Replace the seals if the hubs have to be removed.
The diff is really easy to remove from the car. The socket head screws on the axles are a pain to break loose the 1st time. They have serrated binder heads on the underside of the head which bites into a metal washer plate that spans 2 bolts. Clean any dirt out of the sockets with a small screwdriver & compressed air & use a breaker bar on a hex bit or a pipe on an allen wrench. The diff drops out by removing the 2 bolts on the rear bracket and the single bolt on the front of the stamped sheet metal plate. The plate stays on the diff. The diff is heavy, it weighs approx. 92# so be ready with a floorjack.
It might get a little dicey if you have to swap the input hub, the preload on them is factory set and establishes the clearance between the ring & pinion gears. If merely removing the hub to replace a seal, and putting the same hub back on, one can scribe a mark on the nut & hub & retorque it to the same position. You might be able to successfully swap them if you scribe a mark and measure the torque required to line the mark back up, and apply that torque to the swapped hub & neglect the mark. If the preload isn't set correctly, the diff can fail within 1000 miles.
