Thread: Lambda Control #2
    Mar 2004
    Default Lambda Control #2
    My car was stuttering on the highway. I came home and tried to restart it and it had a rough idle, then when I tried to take off, it died on me.
    I read the fault code and it was "Lamda Control #2" which is Oxygen Sensor #2.
    I did some research and found out this may be due to various things, such as:
    1) Bad O2 sensor
    2) Bad spark plugs
    3) Intake Manifold Leak
    I will change spark plugs and both O2 sensors but I wanted to know
    how do you check for Intake Manifold Leak? any other suggestions?
    PA
    Quote Originally Posted by ronn227
    1) Bad O2 sensor
    2) Bad spark plugs
    Quick an easy vacuum leak is to pop the oil cap, the idle should change a little bit. If that doesnt work you can go and get throttle bottle cleaner spray and start spraying cracks where gaskets meet, if you find a leak, the fluid will be ingested and the RPM will change.
    Mar 2004
    what spray should i use to check hoses? A non-flamable spray like electronic cleaner? Or something with Ether, like starter fluid. I read in an archive that the ether will change the rpm's if ingested.
    PA
    You could use starter fluid, I use TB cleaner. Try not to soak hoses, it can't be good for them. Just be careful. I have a boost/vacuum gauge so its easy to tell if im leaky.
    Mar 2004
    what's TB cleaner? Would the RPM's increase with any spray?
    Because spraying Ether (Flammable) on the hoses seems a bit risky. I'd feel safer spraying something non-flammable like electronic cleaner, but would electronic cleaner make the rpm's rise if a leak was found?
    Mar 2004
    anyone?
  1. Lambda Control Question- Peake
    Last Post: 05-09-2009, 11:54 PM
  2. Lambda Control 1 Engine Code
    By unhygenix in forum 5 Series BMW
    Last Post: 06-15-2007, 01:27 PM
  3. code 1222 Lambda Control 1 what is wrong
    By cobb535 in forum 5 Series BMW
    Last Post: 03-10-2007, 09:33 PM
  4. Code 1222 - Lambda Control
    Last Post: 12-04-2005, 04:09 PM
