Results 1 to 9 of 9
Thread: can somebody tell me how to check for r134 or r12...
    Benneton (United Colors of)
    Default can somebody tell me how to check for r134 or r12...
    i was certain up to about 20 minutes ago that my system was r134, until I saw my underhood sticker said r12, but i'm certain that I saw service records indicating a compressor replacement no earlier than 1996 or 1997...would somebody try to retain that stuff if the system was opened up during that time? is there a valve unique to 134 that i can use to rule out the presence of the 12 stuff? thanks.
    the valves pretty much tell the story, R-12 is the small thread deal and the R-134 is the wider thicker thread model. That is entirely based on who and what they did when or when not retrofitting the refidgerant.
    When I converted my 90 GMC 4x4 I simply evacuated changed the drier and added R-409a and didnt add any stickers cause they dont have freezer conversion stickers. If I would have changed the condensor I would have used 134 (not) to be EPA fluent. But since I used the r-12 condensor I used the 409a, have to overfill it so that the evaporator dont freeze humidity solid. Much colder than the 134 conversion and colder than r-12 but not exactly what was meant when they gave me the certificate on that subject.
    doubt that tells your answer but might help, if they retrofitted there will usually be an adapter cap type valve that cannot be removed. If it looks like it makes the threads bigger than its r-134.
    baton rouge, loserana
    i deal with this all of the time, unfortunatly some people don't convert the car as it should be, i allways check the charge with a identfyer (about a $1100 toy from yokogawa) to protect the $4000+ ac machine from contamination, i see all kinds of stuff, r22, r134, propane and any combination there of with no labels or special fittings
    Default where can Ryan get that $1100 dollar unit?
    :d
    Default i think if i'm going to flesh
    this thing out, im going to have to clip one of those 9.99 ac place coupons for a/c system checks and see what they say is in there.
    damn these things got cheep quick, it wasn't long ago that i was looking for my own, id be on this like stink on **** if i didn't just send off $320 this morning for some goodys i got yesterday on the bay
    http://cgi.ebay.com/ws/eBayISAPI.dll...category=53298
    somebody got a deal on the id machine, i only put in a half ass effort on snipeing it, i wasn't about to let it go under 125
    Default rmheat....
    sunk that sub $100 battleship but good.
    409 409 409, colder than anything and not what i would suggest against my epa certification but I heard 409 works well. But I wouldnt personally know of course.
  1. can you use a r22/r12/r502 gauge set for r134?
    Last Post: 09-14-2007, 11:41 PM
  2. R134 Low pressure tap?
    By Boone.Msi in forum 5 Series BMW
    Last Post: 05-25-2007, 08:18 AM
  3. AC compressor R134 compatible or not ?
    By Claude in forum 5 Series BMW
    Last Post: 09-27-2006, 10:24 PM
  4. R12 to R134 conversion question
    By Mr. BILL in forum 5 Series BMW
    Last Post: 09-09-2004, 02:17 PM
  5. Anyone paid to have AC retrofitted for R134 freon?
    By Abnormal in forum 5 Series BMW
    Last Post: 04-19-2004, 09:53 AM
