yep, cant use normal peddle bleeding. i got one from bruno, fixed her right up.
Bentley says I shouldn't try to bleed the brakes on my '95 530 but it doesn't say why. What's the deal? Do I need a pressure bleeder?
David Porter
Glyndon MD
'95 525i T
'95 530i
'72 3.0 CSi
or are looking for the two year fluid change?
As long as you have no air in, you can do it the old way, syringe out fluid, top with new fluid, pump out trough the wheel nipples, far one to close one, keeping air out and fluid in the reservoir.
Color change will tell you when to stop.
Javier
No air, just flush at this point but then I've always wanted a pressure bleeder. . .
Thanks.
David Porter
Glyndon MD
'95 525i T
'95 530i
'72 3.0 CSi
