I need to run oil to the supercharger. thought about a closed loop system but not worth it. I am between tapping the oil pan for the return line and tapping the dipstick. I need to get some lines though. They don't have to be the hole banjo bolt style. I am going to use normal barbed connectors. The oil return hose has to be lower than the blower, which is above the alternator... so I am thinking of tapping the dipstick. I am thinking maybe going to homedepot or lowes and finding a T pipe... like a small diameter T pipe, so I can cut the dipstick in half and weld the T pipe in and weld the dipstick on the other side, once cut down so that it matches OEM length to check oil levels... ugh oil lines suck.
Also, where would be the best place to tap in order to get an oil SEND line TO the blower? Thanks guys.
