Results 1 to 10 of 17
Thread: Less torque/power when warmed up?
    Nov 2004
    Split, Croatia
    Default Less torque/power when warmed up?
    I noticed that my car loses torque/power while getting warmer - when cold, I drive it between 2000 and 3000 rpm and it has satisfying amounts of torque, BUT when the engine is at working temperature, it seems like it lost it's elasticity. It doesn't seem that strong anymore. Engine temp. sensor? Vacuum leak? O2 sensor? Too much stuff to change just to rule out the possibilities. I hope someone can give me some pointers before I become desperate and spend half of my salary just to change 9 working parts and 1 that failed
    Default what grade of gas are you running, if your using the eat chip that you list and
    your not running a high grade premium, then your knock sensors are going to really retard the timing when its warmed up to eliminate pinging and knocking.
    Quote Originally Posted by Interceptor
    Nov 2004
    Split, Croatia
    I am using 95 RON fuel as MarkD suggested. I don't think my car has knock sensors since it doesn't have VANOS - or am I wrong?
    Default Nope,you're right. My mistake i wasn't paying close enough attention to the year
    1
    Toronto, CANADA
    You don't have knock sensors and VANOS. When did your problems start?
    How many km's on the motor?
    How long have you had that O2 sensor in there?
    (if more than 50K km's, it may be time for a new one)
    How is the fuel consumption? Has it decreased? An old O2 sensor usally causes the mixture to run on the rich side.
    There can be many things that will cause your problem, as you mentioned.
    Try swapping parts like the coolant temp. sensor and MAF from a friend's car if possible.
    My guess is that the motor is running a bit lean after warming up. Look for intake air leaks by using an unlit propane torch with the valve just slightly open, and moving it around the intake area while the motor is idling. If it changes the idle speed, you have an intake leak.
    MarkD
    Nov 2004
    Split, Croatia
    Quote Originally Posted by MarkD
    It started a few months ago, before I bought the chip. My mechanic changed 5 injectors and the situation improved significantly, but it's not yet "the real thing"
    Cca. 240000 km.
    This one is 8 months old.
    Fuel consumption is higher than normal - around 13/14 mpg around town.
    MarkD
    I don't have any tools and/or experience in that sort of business
    Hey, it's just flammable gas - you're a man, what more training do you need?
    My 535 pulls harder when cold, I've always considered it a function of air density getting to the cylinders. The engine bay gets pretty hot, and the intake manifold is painted black, absorbing all it can.
    My car definitely has good days and bad days, and usually the colder it is the better. Is it a big difference on your car, like before-and-after-an-EAT kind of difference, or is it only the kind of thing an enthusiast would notice?
    Robin
    72 Chevy K10
    01 E39 M5
    Toronto, CANADA
    Cca. 240000 km.
    13 - 14 mpg? That's terrible. I'd expect at least 20 mpg. (and probably higher, even around town)
    A coolant temp sensor could not be expensive, you can just buy a new one and have the mechanic install it. I bet it's a $25 USD part.
    At the price of fuel where you live, you can afford to change lots of parts to fix this problem as you'll get it back in savings.
    Maybe your fuel pressure regulator is bad, try swapping that also. Again, with the bad mileage you are seeing, you should just take it to a mechanic as your burning off your cash with the high fuel consumption!
    Isn't gas at least $3.00 USD a liter where you live?
    Here are prices from May, 2004:
    http://money.cnn.com/pf/features/lis...ces/price.html
    Nation City Price
    UK TEESIDE $5.64
    HONG KONG HONG KONG $5.62
    UK MILFORD HAVEN $5.56
    UK READING $5.56
    UK NORWICH $5.54
    GERMANY FRANKFURT $5.29
    DENMARK COPENHAGEN $5.08
    NORWAY STAVANGER $5.07
    NORWAY OSLO $4.93
    ITALY ROME $4.86
    TURKEY ISTANBUL $4.85
    PORTUGAL LISBON $4.80
    KOREA SEOUL $4.71
    SWITZERLAND GENEVA $4.56
    KOREA KOJE/OKPO $4.53
    AUSTRIA VIENNA $4.50
    CROATIA ZAGREB $4.32
    JAPAN TOKYO $3.84
    AUSTRALIA SYDNEY $2.63
    CAMBODIA PHNOM PENH $2.57
    TAIWAN TAIPEI $2.47
    GEORGIA TBILISI $2.31
    LAOS VIENTIANE $1.66
    THAILAND BANGKOK $1.60
    CHINA TIANJIN $1.54
    CHINA SHANGHAI $1.48
    RUSSIA MOSCOW $1.45
    KAZAKHSTAN ALMATY $1.36
    KAZAKHSTAN ATYRAU $1.35
    TAJIKISTAN DUSHANBE $1.32
    AZERBAIJAN BAKU $1.15
    VENEZUELA CARACAS $0.14
    Ok, guys, I won't be on the forum for a while, I'm going to drive to Venezuela!
    MarkD
    Nov 2004
    Split, Croatia
    Actually, it's US$ 1.25 a liter. We have the cheapest fuel in the region (Italy, Austria, Hungary and other countries around us have higher prices).
    Regarding the coolant temp. sensor, I will try starting with that and see what happens.
    Thanks for all the info!
    I wish you a pleasant trip and return home safely!
    Nov 2004
    Split, Croatia
    Quote Originally Posted by Robin-535im
    You're right, I'm a man, what else do I need?! OK, my spirits are up
    Actually, when the engine is cold, material of which it's made of is tighter giving it higher compression - that is why you shouldn't drive it hard until it reaches working temp.
    Well, it's not a HUGE difference but it's noticable - well, I notice it, since I commute daily.
  1. OT: Warmed up a bit
    By Jehu in forum 5 Series BMW
    Last Post: 01-01-2009, 11:00 AM
  2. M50 knocking when warmed up
    By RenaissanceMan in forum 5 Series BMW
    Last Post: 05-04-2007, 07:00 AM
  3. The joy of power and torque
    By saluki540i in forum 5 Series BMW
    Last Post: 01-22-2007, 06:47 AM
  4. M20 hesitation when not warmed up
    By DaveVoorhis in forum 5 Series BMW
    Last Post: 03-17-2006, 10:40 PM
  5. '89 535 - Rough idle when warmed up
    By gcraiga in forum 5 Series BMW
    Last Post: 02-20-2006, 04:30 PM
