Thread: 10mm offset?
    Jan 2005
    Ashland, Oregon
    Default 10mm offset?
    The wheels & tires I just mounted measure out at around a 10mm offset. Will this cause any safety issues? I understand my tire wear might be less than desireable, but the car feels fine. I haven't really put her through the ringer yet to examine any extreme handling differences.
    It looks good though.
    16x8 with 225/50s right now.
    here's my thread with pics if you wanna see: http://www.bimmer.info/forum/showthread.php?t=10532
    94 540i / 255k / 165k on the alusil / E.A.T. chip / Power Discs w/Akebono Pro Ceramic / E39 type 33's
    -Brandon G
    you wont have a wear or safety issue. The problem is that they can rub, if it's fine then your good to go.
    Jan 2005
    Ashland, Oregon
    Oh no rubbing... they're sticking slighty farther away from the wheel well than the stocks.
    I figured I'm good to go.
    -Brandon G
    Yep... you are good to go... Your wheels are wider than original wheel so the offset is correct.
    Jan 2005
    Ashland, Oregon
    Quote Originally Posted by Tiger
    DOH! so true... I don't know why that didn't register the first time.
    well, some days I'm a genius... and others I'm a fool. Unfortunately I never know what I'm gonna get from day to day.
    -Brandon G
    Lol
  1. Fuel Filter 10mm bolt/nut
    By txp135 in forum 5 Series BMW
    Last Post: 05-29-2007, 11:58 PM
  2. Offset
    By montsta56 nz in forum 5 Series BMW
    Last Post: 03-21-2007, 08:12 PM
  3. What's the torque setting for the 10mm bolts holding...
    By darren540i6 in forum 5 Series BMW
    Last Post: 07-05-2006, 11:14 PM
  4. 18mm offset on E34
    By baddoc in forum 5 Series BMW
    Last Post: 07-02-2006, 08:50 PM
  5. need help on wheel offset e36
    By juan525i in forum 3 Series BMW
    Last Post: 09-28-2005, 02:50 AM
