Results 1 to 10 of 16
Thread: I need some help with a couple of things :)
    Default I need some help with a couple of things :)
    Firstly Hi everyone, what a nice forum you have here!.
    Ive searched for all the following but cant find any info anywhere, so I'd like to ask a few questions if thats ok .
    I have a 1991 520i 24v, with a few issues.
    Firstly my odometer displays PPPPPP but once in a blue moon it will display the correct millage, and the trip counter resets when I turn off the car, but the guages work correctly, Ive changed all the caps so its not that. Any ideas?. Ive also had difficulty locating a new set of clocks, as mine only has a blue and a yellow plug, all the others I can find have 3 or more plugs, and wont plug in.
    The other problem I have is that the car is awfull on petrol, its worse than my R32 Skyline turbo, it idles fine but seems a little bit lumpy I dont know if thats related?, I havent had any luck pulling codes, as my clocks doesnt have a facility to have a engine management light.
    Any help with the all the above will be much appreciated.
    Thanks
    Dale.
    I'm thinking that the memory chip (do you have one plugged into the back of the module?!) is corrupted. It's an easy thing to do if you pull the dash module and don't disconnect the battery, but it doesn't explain why it sometimes works, other times it doesn't. I'd think a fried chip would be gone for good.
    Have you tested out the dash module? If not, hold down the check control (right) while turning the key to "ON" (don't start the car though), continue holding for a few seconds and release -- it'll run through diagnostics. I'm not sure if it'll do it with the PPPPPP fault, but you could try it out.
    Snap a picture of your dash module and post it? I'm curious to see what the front/back look like. You should have a check engine light, or at least the capacity to wire one. My understanding of it is that after ~ late 89, all cars had them wired; earlier cars are sometimes not wired but can be.
    best, whit
    Austin, TX
    pics of e34 and skyline? sounds like a coding plug might be loose regarding your odometer. change your oxygen sensor, change your spark plugs and air filter and see if your mileage improves.
    whats that PPPPP code mean? I read about that somewhere and looked for about an hour with no luck. Should have broke out the Bently.
    Default Guess it is the default display when the dash looks ...
    for the coding plug information on mileage, and does not find it.
    Guess coding plug is loose, improperly seated or needs a contact cleaning. The issue is that I think I recall from some OBC retrofitting in a 520i reading, that coding plug is not in dash, but in some harness. Can not guarantee though.
    Javier
    Nah when coding plug isnt in properly it will say (CODE), been to BMW, car doesnt have a cat. what can be causing the poor economy/lumpy idle then :S
    Default Funny, PPPP is also the OBC unable to reset display.
    Javier
    I dont have any pics of the bmw, but I have some of the skyline, The bmw is a UK 1991 520i, Electric leather sports seats, 16" 8 series wheels, sport rear bumper, colourcoded front bumber, alpine white, clear front indicators, and the rear indicators have been tinted red and a nurburgring map on the bootlid for good measure!, i'll try and get some pics of it, I bought it as a second car, but im really liking it so much I want an M5 now!. this is my 5th bmw, prior to this I had, E3 3.0s, E28 528i, E30 325i sport (phase one), and a e34 520i 12v (poverty spec, nicknamed gordon)...
    Regarding the above, Maybe uk dash's are not wired for the engine management light, my last e34 wasnt either.
    My dash is odd, my last E34 had a analogue odometer, this one is located below the speedo and is lcd, but my m8's later E34's have the check panel/odometer.
    I did that check, and all the numbers display in sequence, then it tests the gauges.
    Im not 100% sure if its got a lambda probe, we were not that strict on emmisions in the UK till about 1993, but some bmw/audi/volvo had cats as an option, so it may have it, what are the symptoms for a failing lambda on the M50 2.0 24v?
    Sorry about the long post and questions!
    Thanks
    Dale.
    Austin, TX
    Quote Originally Posted by DaleR
    Thanks
    Dale.
    look under there and see if you have a cat, it's right near the passenger footwell on the undercarriage. if you have a lambda (o2) sensor, replcae it, that's most likely your source
    Have you seen what a lambda probe costs in the uk!, £70!!!! I hope its not that, im gonna check it with a voltmeter if I have one...
    Any alternate way of getting engine codes if you dont have the dash bulb?, and where can I find a site with all the codes listed.
    Thanks
  1. Couple little things i need help with!! please!!
    By wyze in forum 5 Series BMW
    Last Post: 04-02-2007, 01:06 AM
  2. What are these things right here? (serious ?)
    By Calico_NC in forum 5 Series BMW
    Last Post: 03-14-2006, 07:17 AM
  3. a couple things...
    By kyleN20 in forum 3 Series BMW
    Last Post: 10-19-2005, 01:59 PM
  4. A couple of things FS
    By Rigmaster in forum 5 Series BMW
    Last Post: 03-04-2005, 09:34 PM
  5. OT: things to look out for in an E36?
    By Phil M in forum 5 Series BMW
    Last Post: 06-05-2004, 12:21 AM
