you could try a seal kit but chances are the fluid wasnt changes periodicly and has water rusting the metal or someone used the wrong fluid and it ruined the seals. I would try the seal kit first and inspect the cylinder bore for rust pits. Then bleed the entire system with fresh correct fluid.
