Results 1 to 5 of 5
Thread: Gas cap difficult to remove (m):
    Minneapolis
    Default Gas cap difficult to remove (m):
    Wife called me and said it was nearly impossible to remove the gas cap off of our 1994 530.
    She said it twisted fine, but that she had a difficult time actually pulling it off, and when it did come off, it made a whoosh (suction?) sound.
    I thought it was wierd that she could *twist* the cap just fine, but not remove it.
    Is it possible that there was enough vacuum in the system to make removing the gas cap difficult? WHat would cause this vacuum? We've never experienced this before.
    Thanks for any and all input.
    Beachcomber
    1994 530ia (4/93)
    1997 540ia (7/96)
    Default Whoosh...
    just like pulling a cork out of a bottle, I seem to have a slight vacuum when I pull mine off too but not to the degree of dificulty that your wife describes. Maybe a combonition of the slight vacuum and the gasket being dirty/sticky is what she experienced. Practice practice practice, maybe you should build some sort of exersize system to build her hand strength?
    Default It could be a real problem if the gas tank ventilation valve is stuck open then-
    You can actually build so much vacum in the tank that it collapses.
    I've seen it more than once.. I would check that valve to make sure its not stuck open.
    Quote Originally Posted by Beachcomber
    had one e34 come in with the tank sucked completly flat, a mud dauber built a nest in the venting system
    Default what valve, huh? where? I should maybe perhaps check this out.
    n
    t
  1. A difficult choice: which color for the mags
    By BMWDriver in forum 5 Series BMW
    Last Post: 04-10-2010, 08:04 PM
  2. 5.25 speakers in kickpannel- difficult fit or not?
    By 530iNoir in forum 5 Series BMW
    Last Post: 11-22-2005, 01:08 AM
  3. Difficult to start
    By Bijosz in forum 5 Series BMW
    Last Post: 05-15-2005, 10:31 AM
  4. Replies: 14
    Last Post: 12-18-2004, 10:22 AM
  5. is replacing the e-brakes difficult???
    By tim s in forum 5 Series BMW
    Last Post: 08-21-2004, 03:35 PM
