Results 1 to 2 of 2
Thread: steering question
    B'ham
    Default steering question
    I replaced both control arms and thrust arms, tighten the nut on the steering. I just tighted the stearing box, however to get the slack out of the steering when the wheel is turned to one side the wheel will not return to center by its self when driving. I hear a small clicking sound when the front end is off the ground and the wheel is turned to one side. I wingle the steering wheel and I hear the clicking. If I tighten the steering the clicking goes away, however then the steering will is very tight. Any ideas?
    Loosen the adjustment on the steering box or it will wear ir out very quickly. The wheel should freewheel back to center, if it needs any help it's too tight. If you still have play then the box is worn a bit.
  1. 89 535 Power Steering Question
    By 89535i in forum 5 Series BMW
    Last Post: 03-31-2006, 11:55 AM
  2. Steering Gearbox question
    By franks in forum 5 Series BMW
    Last Post: 03-26-2005, 04:44 PM
  3. Question for steering gurus....need some help
    By mikemaster in forum 5 Series BMW
    Last Post: 11-25-2004, 12:47 PM
  4. Steering Linkage Question
    By Super90 in forum 5 Series BMW
    Last Post: 06-21-2004, 01:51 PM
