Results 1 to 3 of 3
Thread: Steering lock troubles
    Default Steering lock troubles
    Recently, there have been more than a few posts regarding ignition lock and steering lock problems (some sporatic) with cars not driveable as the consequence. My '90 535i suddenly was unstartable because the key would not turn far enough.
    In studying this problem, I dis-assembled the steering lock, which on inspection is a very simple device. It has an internal camshaft that connects the ignition lock on one end to the ignition switch on the other end. This camshaft (when rotated by turning the key) rocks a lever that in turn locks or unlocks the steering wheel. So, it has only two moving parts.
    There is a small pin attached to the camshaft, probably there to keep the assembly from falling out before installation on the car. This pin fell out of its mounting hole and jammed the movement of the camshaft, so the key would not turn and the car would not start.
    Replacement steering locks are not cheap. Further, the online ETK shows drawings of 4 or 5 steering locks for a '90 BMW 535i. None of these drawings look like the factory steering lock that was on my car.
    So, if your key won't turn, the fault may lie in the ignition lock itself, in the steering lock, or in the ignition switch.
    First, unclip the plastic ignition switch and start the car that way. If the ignition switch does not work, replace or repair it.
    Second, remove the ignition lock cylinder from the steering lock. l found that a heavy duty paper clip, straightened except for a ~25 degree bend ~1/4" from the tip, works a LOT better than an allen wrench. Push the paperclip ~7/8" in, then rotate it. Its curved tip acts as a cam to retract the latch on the igniiton cylinder, which can then be pulled out of the steerring lock housing. Lubricate with locksmith's graphite and repeatedly check the movement of the ignition lock. If there's any resistance or stiffness, replace it.
    Third, withdraw the camshaft from the steering lock, Do this by depressing the lockpin that goes under the inner rim of the steering wheel (which must be removed per Bentley instructions). With the lockpin depressed, the lever moves out of the way and the camshaft can be pulled out with needle-nose pliers. Clean the inside of the steering lock, remove any debris (such as a broken pin) that has been jamming the works. Q-tips, a flashlight, Kleenex and a small dental mirror are handy. Re-lube with lithium grease, and re-assemble in reverse order, first studying the relationship of the cam part of the camshaft and the internal lever. (Insert the camshaft with the cam lobe up, while depressing the lockpin, thereby holding the lever down. This makes enough space to insert the camshaft and seat it in its pivot hole.)
    Knowing this last Friday would have saved me days of frustration, $$$, and the loss of my car for a week. You results and specific car may vary, but this worked for me.
    It's probably smart to get some locksmith's graphite and lube all the locks on your car. My doorlocks got stiff this winter, but are now smooth as silk.
    Thats an excellent write up man! Please tell me you took a butload of pictures to go with it... Hard to imagine all the parts and stuff. Glad you got it going!!!
    Well, Jeff, how many is a "butload?" Actually, I did take 6 or 8, but some are effectively duplicates. This weekend when my kids (better at downloading computer stuff than I) can help, I'll try and attach some, hopefully with captions.
    Not all cars may be like my '90 535i. Later E34s, perhaps in the mid-90s, may have added a cable linkage between the steering lock and the transmission shifter. If so, this discussion may have limited application for those later cars.
    Actually, I'm very lucky my steering lock jammed when it did, about 3 miles from home last Friday night: I'd planned to spend the weekend on a tour through the remote areas of the mountains, and would have been really stuck, and compelled to flatbed the car perhaps hundreds of miles to wait for very expensive dealer repairs and parts on Monday.
    There may be a way to fix this on the car without removing the steering wheel.
    And, I think perhapsthe steering lock can be neutralized to steer the car, if a slender tool can be inserted to pry up and securely hold the steering lockpin so that it does not engage the inner cogs of the steering wheel. Otherwise, the airbag and steering wheel must be removed, which entails battery disconnect, etc. as described in Bentely et al.
    I'm certain the red plastic ignition switch can be unclipped to start and run the car without the key, ig. lock cylinder, steering lock, etc.. Just unscrew the bottom plastic cover off the steering column to expose the ign. switch, then unclip it. Use a key, fingernail file, popsicle stick, etc. to turn the switch to start the car.
    If the steering lock can safely (so it absolutely does not suddenly drop & lock the steering wheel while driving) be secured, a knowledgeable person with little or nothing more than the stock toolkit could start the car and drive home without further assistance from anybody. Nice to know in lieu of a towing & repair bill that could run into many hundreds of dollars, plus potentially days of inconvenience & delay on the road.
    QUOTE=632 Regal]Thats an excellent write up man! Please tell me you took a butload of pictures to go with it... Hard to imagine all the parts and stuff. Glad you got it going!!![/QUOTE]
  1. e30 help steering lock
    By Macv in forum 5 Series BMW
    Last Post: 09-03-2012, 07:50 PM
  2. Steering lock?
    By guinness in forum 5 Series BMW
    Last Post: 10-23-2008, 05:40 PM
  3. Broken Steering Lock
    By Chrisdevon1 in forum 5 Series BMW
    Last Post: 08-16-2005, 03:17 PM
  4. HELP PSE Steering column lock!
    By ggrigg in forum 5 Series BMW
    Last Post: 03-14-2004, 03:50 AM
