Here is the problem:
After starting the car, I cannot control the heating or cooling. When I turn the rotary dials (both driver and passanger) it does not make any difference. When I push the AC switch, light comes on, but AC does not work. The light on the air circulation button comes out but I don't hear any vent closing sound. When I push the rear defogger switch, nothing, no light. After driving the car about 20-30 minutes (when the car is really hot), suddenly everything starts working; I hear some noise (like a vent closes or something), then I know things work. AC, rotary dials, air circulation (it closes and opens some vents with a loud noise), and rear defrost switch with the light. I think I have a bad heater valve, because the passanger side heat is just warm, does not get hot like the driver side when things start working.
I think I have some connection problem as well, or at least I suspect. It seems like, when the car is really warmed up, somewhere, somewire makes the connection, but I am not sure where or if this is the case. Has anyone had the similar problem? Before replacing heater valve, aux. water pump etc, can you tell me where the good place is to check for wires? I changed all the fuses related to heating/cooling. I did a search and read everything related to heater valve, but I think something else is going on, since everything suddenly starts working after driving the car a little. Thanks. By the way, car is '95 525
