Enough for everything except the wheel hub bolts (214 ft/lbs) and perhaps some crankshaft bolts.Originally Posted by liquidtiger720
Oh, absolutely click type. Beam wrenches work, but half the time they're useless because you can't see the damn scale without contorting yourself into some terribly akward position.2. Clicker type or beam type? I was leaning toward clicking type.
Not for quite some time, as long as you store them with the tension set back at 0 ft/lbs.3. Do the clicker type's have to be recalibrated? If so, how much would it costs, how often would I have to do it, and where?
That's the one I have. Works fine for me.4. How does this one look? I was eyeing this the last time I was at sears, and its on sale now. http://www.sears.com/sr/javasr/produ...orque+Wrenches
Na, not enough to matter. Using a long extension could, however.5. would having a 1/2 - 3/8 inch socket adapter effect the torque values?
