Thread: what tire size for 16s?
    Default what tire size for 16s?
    i think i know what size but better ask. Im going to convert to 16s for the summer treads.
    Thanks!
    Default use this to figger it out and keep da speedo right
    can you go and measure my tires circumfrence for me? Its cold out there.
    just punch in 225/60/15 and use that for the refrence size
    Albuquerque, NM
    Default 16" tires
    Check Tirerack's page & pick your favorite tire and then click on "Spec's", it will give you tire diameters for all sizes. Stock for my e32 is 225-60-15 which is about 25.6" to 25.7" o.d. depending on brand. I've been running 16" tires for a year or so & they make a great compremise for comfort and handling. My next set of tires are going to be staggered with 245-50-16 in the rear & 235-50-16 in the front if they clear, otherwise 225-55-16 in the front. I prefer to go with no more than a 50 profile, 55's are a bit mushy for a summer tire.
    Then again, if you go to a minus 1 like a 225-50-16, it effectively tweaks the final drive ratio and will give a bit better lowend performance & the smaller tire offers better turn-in.
    gale
    Jan 2005
    Ashland, Oregon
    225/55/16 seems as close as you can get based on a bone stock size of 205/65/15.
    Although if your wheels are wide enough(say...16x8), I think a 235/50/16 would be a great choice.
    I've used this java page for as long as I can remember to calculate correct tire profiles: http://www.miata.net/garage/tirecalc.html
    94 540i / 255k / 165k on the alusil / E.A.T. chip / Power Discs w/Akebono Pro Ceramic / E39 type 33's
    -Brandon G
  1. tire size
    By h2oyo in forum 5 Series BMW
    Last Post: 04-21-2009, 05:36 PM
  2. tire size
    By charlie in forum 7 Series BMW
    Last Post: 10-20-2007, 06:20 PM
  3. Tire size ?
    By Herb in forum 5 Series BMW
    Last Post: 04-30-2007, 02:26 PM
  4. possible alt. tire size?
    Last Post: 04-05-2007, 08:35 AM
  5. Rim and Tire size
    By Borgiulo in forum 3 Series BMW
    Last Post: 01-10-2006, 12:43 PM
