I bought a '92 525 about a month ago, the first time we had a 0 degree morning, it would not start. It cranks, but will not turn. I jumped the fuel pump relay, the pump runs and I hear fuel in the rail, but it will not turn. If I do not jump the pump and just use the relay, I get no power at the fuse when I crank, this leads me to believe something is disabling the relay. Based on my reading of this thread, I decided to test the crank sensor. I removed the allen bolt, but it will not budge. I have pulled with all my force and nothing. The wire does not come loose, there are no release tabs and I am throughly frustrated. Am I even barking up the right tree? I can't even figure out how to test for spark. I thought I would pull out one of the wires, but I got quite the surprise when I removed the top engine cover; where are the plugs?! I am new to the thread and new to this car. I would greatly appreciate a hand. Thank you. Jesse
