Results 1 to 5 of 5
Thread: Is this coolant loss normal??
    Jul 2004
    Perth, Western Australia
    Default Is this coolant loss normal??
    Got in my car today and got the check coolant warning when I started up. I had to put in around 700ml into the reservior. It is a 1990 525 (M20), and we have just finished a hot summer here. My fan clutch needs repacing, so the engine temp has usually been running at about 1 needle width past half. There are no visible coolant leaks, I had new hoses, water pump and coolant change about 20,000kms ago.
    The car runs fine, no loss in power, oil colour is normal..... would this be the normal result of a hot summer???
    Garry - Perth, Western Australia
    Wellington,New Zealand
    might be a slow leak.....keep an eye on it,sometimes it easier to find these leaks with a torch when you are in a dim garage ...the little pools of brightly coloured coolant show up better,look in all the nooks and crannies in the engine bay anywhere near a coolant hose,including the overflows and resevoirs......
    Gone but not forgotten
    you have a leak. I replaced all my hose stuff and while inspecting the engine compartment rear of the engine I saw a pile of what seemed to be a waxy deposit of cool blue in the top of the trans. Sure enough the clamp on hose above was about 1/2 turn loose. checked all the clamps and most of them could be tightened a bit more.
    Maryland
    Default Venting due to hi temp?
    Is it possible that running a higher temp due to the bad fan clutch is causing a bit more expansion and venting than normal?
    Jul 2004
    Default Thats what my thoughts are...
    [QUOTE=danzee]Is it possible that running a higher temp due to the bad fan clutch is causing a bit more expansion and venting than normal?[/QUOT
    I have ordered a new clutch, should get it today, so i will see how it goes over the next few weeks.
  1. Sudden loss of power, then normal - why??
    By romus in forum 5 Series BMW
    Last Post: 11-14-2005, 11:40 PM
  2. Coolant loss- 95 525, M50
    By peterllo in forum 5 Series BMW
    Last Post: 11-02-2005, 03:31 AM
  3. Coolant loss
    By Mr. BILL in forum 5 Series BMW
    Last Post: 12-28-2004, 11:46 PM
  4. Coolant Loss
    By Alan_525i in forum 5 Series BMW
    Last Post: 12-07-2004, 05:01 PM
  5. '93 525i normal coolant temperature range?
    By ACir in forum 5 Series BMW
    Last Post: 05-05-2004, 07:28 PM
