Results 1 to 2 of 2
Thread: 24 Valve Head
    Mar 2004
    Brisbane, Australia
    Default 24 Valve Head
    Hi guys, does anyone know if the 24v head off a 2.5 will fit straight onto a 12v 2.5? If it does, what do u have to change with regards to the timing chain on the 12v engine? is it just the crank pulley or do u have to change the crankshaft as well to accomodate the timing belt? Was considering the swap on an E30 325i sport. Anything else i should know while on the topic?
    Philly, PA
    I've heard of people attempting this swap at enormous expense. You are better off just swapping in a whole M50 motor, it is well documented and much cheaper in the end.
  1. How to remove check valve in M50 cyl head?
    Last Post: 01-01-2008, 12:40 AM
  2. milled head + euro motor = thicker head gasket?
    By 31Hertz in forum 5 Series BMW
    Last Post: 07-30-2007, 05:50 PM
  3. Replacing cylinder head valve cover gasket
    By Peterv in forum 5 Series BMW
    Last Post: 11-25-2006, 01:26 AM
  4. M50 head refresh - what brand valve seals to use?
    Last Post: 08-17-2006, 08:14 AM
  5. Replies: 17
    Last Post: 05-02-2005, 03:47 PM
