Results 1 to 5 of 5
Thread: Is there more than one alternator for the M30?
    NYC
    Default Is there more than one alternator for the M30?
    Mine died this morning and i want make sure i get the right one and I dont know if they used a different one for E28s. If anyone has any info it would be appreciated. TIA
    J
    NYC
    Default Also, what should they go for?
    I need to get one locally and i dont have time to go through BMA. For the most part they are rebuilt ones right?
    Nashville, TN
    Quote Originally Posted by Jason
    part # 12 31 1 466 088 Alternator 140 Amp
    part # 12 31 1 466 091 Alternator 115 Amp
    You need to see which one your car came with, I would guess the 140A. I would not skimp on the source for the alternator. You should get a Bosch reman - a lot of the local rebuilt stuff is junk. Will blow up 6 months after you put it on.
    Derek A.
    90 535i 5 Speed - Style 5 17"
    Default alternator
    Is it a failed alternator, or just the voltage regulator?
    Could even be a simple as replacing worn regulator brushes, which cost next to nothing.
    If just the regulator, an aftermarket replacement (including brushes) can be had for ~$13 at local parts stores, and it plugs into the outside rear of the alternator case. Just be sure to disconnect the battery first, making note of the radio anti-theft code before you do, to re-set the radio after reconnecting the battery.
    The Bosch voltage regulators cost abt. 45 $. But there are much cheaper no-name products on the market like this one:
    http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
    This might not fit yours, but you could contact that company.
    Have no experience with these no name regulators, maybe someone can tell his experience.
    I also want to buy a spare voltage regulator for my E32 750iL VIN 3055570. Does someone know the Bosch number for that and/or the number of one of the no-name products. It is just for spare, so only just for day X when I do not want to pay the $$$ to the dealer.
  1. 540 e34 alternator
    By pheno in forum 5 Series BMW
    Last Post: 03-27-2008, 03:57 PM
  2. E34 Alternator
    By Danog22 in forum 5 Series BMW
    Last Post: 06-15-2006, 03:48 AM
  3. alternator ??
    By Dr. evil in forum 5 Series BMW
    Last Post: 01-26-2006, 08:43 PM
  4. Alternator?
    By howdydee2003 in forum 5 Series BMW
    Last Post: 11-22-2005, 07:38 PM
  5. Anything else I should do while the alternator is out:
    By Beachcomber in forum 5 Series BMW
    Last Post: 05-05-2004, 11:19 AM
