Results 1 to 10 of 10
Thread: New tire time/front suspension work
    Default New tire time/front suspension work
    I'm getting the shakes, have for a while (not like I spend a lot of time in the 55mph range). Ordering the following:
    lower control arms (l/r)
    thrust arms (l/r)
    750 bushings
    bilstein sport struts (l strut is leaking a bit now)
    new bump stops
    ball joint (l only due to some issues)
    Am I missing anything? Should I replace the upper control arms also?
    Tirewise....I have stock bottlecaps (15"), can I run a 60 or should I stick with a 65?
    TIA,
    rick (who is never here anymore)
    NC
    Quote Originally Posted by rickm
    thrust arms (l/r)
    750 bushings
    new bump stops
    TIA,
    tie rod ends
    center link
    pitman arm
    idler arm
    I did all the above about 30k miles ago, and it made a WORLD of difference!
    Bill B.
    95 525i
    Mar 2004
    Phoenix, AZ
    Default Thrust arms are the same as upper control arms, right?
    thrust arms (l/r)
    750 bushings
    new bump stops
    TIA,
    Hi Rick, whats up?
    Dont need bumpstops with the bilstein sports, there built into them shocks. If money isnt an object then replace the uppers, if it is an object then you should have them inspected before you guess.
    Take care!
    Default Rick, the thrust arm functions as the upper control arm and if
    you replace both the thrust arm and the lower control arm then you've replaced both ball joints already since they are part of the arms...As Bill B said you might want to check the tie rod ends and the center link and idler arm also..and the upper strut bearings or strut mounts whichever term you prefer...
    thrust arms (l/r)
    750 bushings
    new bump stops
    TIA,
    Regal:
    Not much, same old/same old. About ready to start a new job that's going to have me driving my own car more (until they get me a car), so I want to make sure this thing is running sweet before then. Other than that nada.
    Patrick hooked me up, I'm ordering in the morning. While I'm at it I'll replace everything up there...when summer rolls around I'll do the rear shocks and related material.
    Tires...with 60 series fit on the 15x7 rim? Or is that too much?
    California
    You mentioned new tire time... I had violent shakes at 55+ awhile back and thought I needed a wheel balance. Turns out one of my tires was just a little too bald. I got new tires and that fixed the problem right up. I was shocked because the tire did not look extreamly bald.
    Default forgot to add your tire info...
    Regal:
    Patrick hooked me up, I'm ordering in the morning. While I'm at it I'll replace everything up there....when summer rolls around I'll do the rear shocks and related material.
    will fit no problemo.
    Jeez....938.00 in parts already.
  1. Tire wear on lowered suspension
    By Vanguard in forum 5 Series BMW
    Last Post: 10-12-2007, 02:54 PM
  2. Suspension work
    By andyman32 in forum 5 Series BMW
    Last Post: 06-09-2004, 06:44 PM
  3. Replies: 6
    Last Post: 04-23-2004, 08:58 AM
