There's a nut & bolt where the clutch pedal is attached to the master cylinder that rotates. The rotation of the bolt raises or lowers the pedal. The nut is a locking nut that you can get to under the dash and above the pedals. I adjusted mine but there's still about a 1/4 " difference. Loosen the lock nut a bit and rotate the bolt head.
