Results 1 to 10 of 11
Thread: m50, 5speed clutch problem
    chicago (NOT chicagoland)
    Default m50, 5speed clutch problem
    My clutch is making these whining & scraping noises when i step on it. The whining is constant pretty much, but the scraping is intermittent.
    This can be felt thru the clutch pedal, thoughout the travel except all the way down.
    It started all of the sudden during the week. Hasn’t gotten progressively worse.....just showed up and has taken roost.
    I’m figuring that this is the original clutch and i have detected clutch slip when pavement was dry and i’m being aggresive (think drag racing). But this was months ago.
    I had in mind to replace the clutch before the comming ‘season’ (autoX hpde etc) but also wanted to replace the exhaust, tranny maybe motor mounts. Freshen things up, ya know.
    Ideas? I wanna nurse him in his present state, till i get some time/funds.
    94 530iT&A, ‘Helga’---92 325i, ‘Rolf’…….”Hang up & Drive!”.......no, SERiously.
    ”Bet that phone call doesn’t seem that important now does it, huh." Nov 20, 2004
    Los Angeles
    Mine did the exact same thing after squealing for a while courtesy of the throwout bearing. I got a lot of feedback through the pedal, and had a crunch at the bottom of the pedal travel.
    I had the clutch replaced and the problem went away.
    Dave
    Quote Originally Posted by paul p (chi-town)
    dave b
    93 525i
    156k +
    Nashville, TN
    If you let that go - you run the risk of damaging the flywheel. It sounds like the throwoutbearing is on its way out. It will eventually come apart and could jam up the clutch. That car uses a dual mass flywheel - not sure if there is a single mass replacement - those dual mass units are expensive.
    Derek A.
    90 535i 5 Speed - Style 5 17"
    baton rouge, loserana
    yep throw out bearing or pressure plate is in the process of crapping
    Feb 2005
    Redmond WA
    Yep, throw out bearing. When mine went out it seized and broke several of the fingers off the pressureplate. The clutch then was permanetly engaged. For the flywheel, I talked to someone who said they were going to use a e28 535i flywheel to eliminate their duel mass one. I don't know if this works, but they had the part and had a shop that was going to do it.
    Default An option?
    Quote Originally Posted by crashnburn80
    Well that is now the $60000 question (ok maybe $600) dunno.
    I suppose if i pull him out of service immediately i may get away w/ a fly-w resurface.
    And hope that the guibo on das schleppen lasts for a week of daily flogging.
    Crap!!!
    Ok as if that wasn’t enough, the OTHER rear door latch mechanism decided to stop working this morning on teh 3er.
    Yup both rear doors are now kept closed w/ bungee cords.
    And today would have been a perfect time to put the rice-car back into service. Xcept some s-mom had totaled it last fall. Ugh!!! You know ‘Jenny’ fired right up and settled into a beautiful, deep but smooth idle (for a 4 banger).
    Los Angeles
    You're right - it's the $600 question.
    Mine was $500 + $100 for the guibo, which seemed logical to do at the same time. Good luck.
    Crap!!!
    dave b
    93 525i
    156k +
    Jul 2004
    Chicago
    Paul,
    I have a stock 525i cluch + flywheel from my '92 525i (e.g., non-Vanos M50) that I no longer need... I pulled it from my car when I changed to a light flywheel + M5 cluch. It was in good condition when I pulled it. It should work for your e36.
    Are you interested?
    -jack
    [QUOTE=paul p (chi-town)][color=indigo]My clutch is making these whining & scraping noises when i step on it. The whining is constant pretty much, but the scraping is intermittent.
    Jul 2004
    Chicago
    Oh - BTW - I live in the 60610 zipcode: downtown.
    [QUOTE=SlidingAlong]Paul,
    Are you interested?
    -jack
    Jul 2004
    Chicago
  1. Sqeaky clutch. Is this a problem?
    By bbig119 in forum 5 Series BMW
    Last Post: 04-23-2007, 12:15 PM
  2. New E34 535i 5speed owner! Problem already.
    By Waynegro in forum 5 Series BMW
    Last Post: 05-24-2006, 09:54 PM
  3. clutch problem
    By grave77 in forum 5 Series BMW
    Last Post: 08-19-2005, 02:24 PM
  4. is this a clutch problem?
    By Matt M. in forum 3 Series BMW
    Last Post: 08-29-2004, 04:13 PM
  5. Transmission/New Clutch problem. Help!
    Last Post: 05-06-2004, 10:51 PM
